22 Users Online (20 Members):
Forums >> Revit Structure >> Technical Support >> hatching foundation walls
is there a way to show concrete walls as shaded and only halftone. The concrete pattern interferes with the reinforcing and sometimes you can't see the reinforcing (for instance #4 bars) unless you lie about the size of them.
So we would like to shade our concrete walls (that are in section), but only shade them with a halftone. Is this possible?
Yeesh - Where is My Cad
Yeesh - Where is My Cad |
Any chance you can upload an image of what you are seeing and an image of what you want it to look like?
**Using Revit Architecture 2009, 2011, and 2012** |
If the section is course, change the course scale fille pattern. If not, use filters to change the cut pattern and color.
I just use a modified concrete material that has a grey solid cut pattern. Then the rebar sits nicely on top.
This video my help > http://www.youtube.com/watch?v=2fm7kAbFjow
hatching/visibility issue |
Wed, Mar 26, 2008 at 3:10:44 PM
Foundation walls in elevation |
Sun, May 22, 2005 at 8:46:49 PM
Hatching |
Wed, Nov 7, 2012 at 11:02:10 AM
Foundation Walls not mitering? |
Fri, Jan 25, 2008 at 9:10:52 AM
hatching line doesn't show in callout views |
Thu, Jul 26, 2012 at 7:10:09 AM
