Forums >> Revit Systems >> Technical Support >> Recessed Can Spotlight does not show through Ceiling?
Fri, Nov 25, 2011 at 10:01:10 PM | Recessed Can Spotlight does not show through Ceiling?
solarflare
Hi Guys,
I am having trouble with recessed can spotlights in Revit, they apply in the model fine; when I attempt to render the scene they do not appear to be showing.
I have checked the obvious things like if the lights are on in the render section, artificial lights only etc.
I edited the family quickly and noticed that the 'Tube' for the light to pass was a void extrusion, I went to the trouble of extending this further past the reference plane but that didn't even help in them penetrating the ceiling.
Is this an issue with linked files? Do I need to add the fittings to the architectural model and not the MEP system model. I modified the ceiling from 'Compound' to 'Basic'  but that didn't change much.
I ended up moving the light source down a little and it has now shown some light, albiet not very nice.
Sat, Nov 26, 2011 at 10:04:18 AM | Recessed Can Spotlight does not show through Ceiling?
The light obviously does not cut the ceiling and that would be true if the ceiling is in a linked model.
Sat, Nov 26, 2011 at 11:27:33 PM | Recessed Can Spotlight does not show through Ceiling?
solarflare
Your a genius, Ill give that a go ;-)
Sun, Nov 27, 2011 at 12:43:03 AM | Recessed Can Spotlight does not show through Ceiling?
solarflare
Hmmmm WWhub can you bind in a ceiling from the architectural model? Looks like Im going to have to delete the ceiling plans and start again. :-(
Sun, Nov 27, 2011 at 10:11:21 AM | Recessed Can Spotlight does not show through Ceiling?
Why not just copy the ceiling into your model and have your lights hosted in it, then turn off the linked files ceiling.
recessed Lighting for a curved ceiling or roof ceiling?
Fri, Jun 27, 2008 at 11:06:24 AM
Recessed cans in family
Sat, Jan 14, 2012 at 4:48:35 PM
Can't figure out how to insert Recessed Can lighting into ceiling plan
Mon, Aug 16, 2010 at 12:50:05 PM
Recessed cans = no light
Fri, Mar 6, 2009 at 7:41:57 AM
Light Fixture - Recessed
Fri, Nov 13, 2009 at 9:14:57 AM
Page generation time: 0.5394
