Forums >> Revit Building >> Technical Support >> Scale Furniture
Fri, Nov 25, 2011 at 7:57:04 AM | Scale Furniture
ossosso
Hi!
I'm inserting in a project a series of components/furnitures.
For example I'm inserting the .rfa of a sofa.
I'd like to change dimension to the sofa, just to scale it down in width and length, accordly with my project, but:
1-The Scale Tool is no accessible once selected the sofa (probably it works just with some kinds of elements)
2-Once selected the sofa under "Edit Type" there are not parameters for dimensions
3-If I insert an "Aligned Dimension" constraint it doesn't work too.
So.. the only way to scale a component is to edit the family?
Thanks a lot!
Fri, Nov 25, 2011 at 8:22:55 AM | Scale Furniture
4 Stars: 205 Votes
That "Sofa" was created in revit OR is an imported object like a CAD file?
I believe it's a CAD file, so, edit that family and scale that.
Fri, Nov 25, 2011 at 8:33:48 AM | Scale Furniture
ossosso
I've downloaded it like .rfa file from the revitcity download section
Fri, Nov 25, 2011 at 9:08:46 AM | Scale Furniture
ossosso
If I import a .dxf furniture the scale tool is available... so what I should do is to export the .rfa in a CAD format (dwg, dxf...)
and reimport it..???
Fri, Nov 25, 2011 at 9:13:59 AM | Scale Furniture
4 Stars: 205 Votes
No, just open that family and use the "Scale" tool, save and "load into project"
Furniture Tags & Sketchup Furniture Components
Fri, Dec 4, 2015 at 9:35:33 PM
scale bar for elevations and sections
Fri, Jun 22, 2012 at 8:15:58 PM
Difference between Furniture & Furniture Systems
Thu, Jan 4, 2007 at 2:37:47 PM
Turning off Certain Furniture
Tue, Jun 20, 2006 at 2:09:52 PM
Filled furniture
Fri, Jul 17, 2009 at 12:06:56 PM
Page generation time: 0.4158
