23 Users Online (21 Members):
Forums >> Revit Building >> Technical Support >> sky in 3D?!
5 Posts No Rating |
How can I get the sky to show up in a 3D drawing "Revit"?!
5 Posts No Rating |
Okay. I figured out how to do the sky. but now, when I try to render, rendering starts at level 1, but I want it to start below level one, @ -4' 2", so to show part of the basement. Is that possible?!
>>I tried to change the graound plane height, but it did not work.<<
Post edited on 2005-12-07 21:25:37
20 Posts No Rating |
You change the rendering 'level' in the 'sun and shadow settings' dialog box, you'll see the "ground plane at level" box on the lower right. Check it and then pick the floor level you want to use as the ground plane. (in Revit 2009)
Rendering with no sky. |
Sat, Mar 21, 2009 at 2:49:59 PM
11
Trouble with sky for rendering |
Wed, Jul 21, 2010 at 9:10:26 AM
RAC 2009 Sky Rendering Problem |
Thu, Jul 10, 2008 at 7:37:36 AM
How do you get a sky? |
Fri, Nov 26, 2004 at 4:42:15 PM
No Background Sky |
Sun, Apr 12, 2009 at 3:51:57 PM
