Forums >> Revit Building >> Technical Support >> Topography Scale
Thu, Nov 24, 2011 at 3:15:36 PM | Topography Scale
CRB14
Hi there,
I've built a topography and set the scale to 1:100. However, when I dimension any of the land, it measures 500 for 5m (instead if 5000). Is there an easy way to change the scale so that the dimensions all correlate properly?
Thanks
Fri, Nov 25, 2011 at 3:27:35 AM | Topography Scale
4 Stars: 205 Votes
Change the "Project Units" I believe you have that in CM (centimeters) and you want that in MM (milimeters) correct?
adding topography not to scale
Sun, Mar 5, 2006 at 10:28:45 PM
Rendering Elevation 3d views with scale
Tue, Aug 14, 2012 at 9:43:43 AM
Topo coarse scale fill color
Fri, Jun 15, 2007 at 10:00:13 AM
TOPOGRAPHY SPLIT PROBLEM
Mon, Sep 22, 2008 at 2:51:42 PM
Topography
Wed, Oct 19, 2016 at 6:19:21 AM
Page generation time: 0.4969
