8 Users Online (6 Members):
Forums >> Community >> Newbies >> MEP families are missing?
1 Posts No Rating |
Hi guys.
This is my first post. If it sounds as if I don't know anything about this it's because I don't. Hopefully you can help me solve this little annoying problem.
My partner has created a building in Revit Architechture 2012, and now I want to draw the HVAC systems for the building, but for some reason, all the standard ducts, air terminals and duct fittings are not loadable in this project, despite it being perfectly usable in a "new" project. This bothers me a lot since I can't make a continous ventilation duct, but has to draw every bend and tee individually.
Please help!
/AAU-Rasmus
You don't say what program you are using. Revit MEP has these items in its library.
so are you actually missing the families? or are you just unable to use the automatically.
If your missing the fitting families, they should be in your library under \Duct\Fittings\Rectangular
If you have them loaded but they don't drop in automatically, this means that defaults are not assigned. Select your duct, then click 'edit type', then assign your default fittings. Similar to the attached image.
Missing MEP Library |
Fri, Apr 19, 2013 at 4:10:43 PM
ID Numbers and Unasscoiated Families In Revit MEP |
Tue, Nov 29, 2011 at 12:12:18 PM
Default templates and families missing from Revit 2016 |
Sat, Jul 15, 2017 at 10:14:48 AM
Revit MEP equipment tags |
Tue, Nov 5, 2013 at 1:29:58 PM
Mapping Revit MEP Families to MEP Fabrication Parts |
Fri, Dec 16, 2016 at 8:35:47 PM
