15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> View Range :Option Question
18 Posts No Rating |
Hi!
I've started Revit using the default Italian Template.
There are 2 level (ground floor and first floor).
I've built a really simple square building (4 walls) of 2 floors. I've put some doors in the ground floor and then I've switched
to the next level to insert some window in the first floor.
While I'm in the second level (1st floor) I can see in viewport also the doors of the level below (even if they have a
light grey color and not all black).
My question is: how can see in level 1 only items in level 1 and in level 2 only items in level 2?
Using the "View Range" Option (in level 2 viewport) seems to solve no the problem (setting both parameter "Bottom" and
"View Depth Level" to the hightest level).
It's hard to manage complex project 'cause while I'm on a level above I can accidently select something below. and so on.
Thank you very much.
Change the "Underlay" option in that view properties.
Thank you, now it works
view range issues |
Tue, Nov 18, 2008 at 5:06:43 PM
view range on uderlay inconsistant with view range of plan view |
Thu, Sep 4, 2008 at 3:48:11 PM
question using view range |
Mon, Apr 6, 2009 at 1:41:24 PM
Modify the View Range Settings |
Fri, Mar 28, 2014 at 8:42:50 PM
view range |
Fri, Sep 7, 2007 at 2:28:04 AM
