28 Users Online (26 Members):
Forums >> Revit Building >> Technical Support >> Schedule Question
18 Posts No Rating |
Hi guys, how can I tell a wall that at every 600mm there is going to be a stud in that wall? Likewise how can I calculate how many sheets of plasterboard ill need for a wall if a standard sheet is 1.2mx2.4m?
Dell Precision T1500 Intel(R) Core(TM) i5 CPU 660 @ 3.33GHz Installed Memory 4.00 GB |
Are you asking how to model studs in walls? If so, we don't normally model this and Revit does not have a built in way under wall definitions. You can read how others are doing this by searching previous threads.
For your quantity question - Remer, Revit is not an estimating program but it can give you material take-offs of what you have modeled. Be careful here. If you model a wall with drywall two stories high, the material take-off will be for what is modeled even though your dyrwall may be interupted at floors and ceilings.
So this means, you have to take your modeling into consideration and you have to add a % for waste.... YOU HAVE TO.
Hi hub, no I dont want to model the studs I just want Revit to tell me on a schedule how many studs i would require if a stud is placed at every 600mm
Wall length / 600 seems to be the equation.
Thanks hub where do I unput this equation?
In a wall schedule with an added - calculated field.
There is a lot of information in your HELP under schedules.
Schedule question |
Mon, Oct 29, 2018 at 8:33:31 AM
Room finish schedule question |
Wed, Jul 8, 2009 at 3:33:52 PM
Schedule Question |
Fri, Oct 24, 2008 at 1:24:24 PM
Quick Wall Schedule Question? |
Tue, Oct 21, 2008 at 12:40:21 PM
Door schedule question |
Thu, Sep 17, 2009 at 2:42:30 PM
