Forums >> Revit Building >> Technical Support >> Revit Exports DWG Sheet to 0,0,0 not correct coordinates.
Wed, Nov 23, 2011 at 9:47:07 PM | Revit Exports DWG Sheet to 0,0,0 not correct coordinates.
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Hello all,
When I export DWGS from a sheet that is setup in Revit, the buildings export relative to Project 0. However in order to ensure our issued DWGS sit correctly as per the site coordinates we need it to match the real cooordinate system.
I know that when you export a DWG from Revit from not within a Revit setup sheet then it exports to the correct coordinates. But I really dont want to have do 2 DWG exports for every one of our 125 sheets for every issue that we make.
Is there a script routine anyone has heard of that can fix this? A tick box I'm missing?
Thanks in advance
Beau
Thu, Nov 24, 2011 at 7:53:20 AM | Revit Exports DWG Sheet to 0,0,0 not correct coordinates.
Download the Spring 2009 issue of AUGUI / EDGE and read this article:  Getting Oriented With Revit’s Coordinate System
  It should help you with this.  A link to this is on our Home Page.
Thu, Feb 23, 2012 at 5:48:16 AM | Revit Exports DWG Sheet to 0,0,0 not correct coordinates.
Djailes
Did you find any solution? I read the article, but it didn't really help. I have the same problem, with a lot of sheets to export and no possibility to keep integrity of coordinate system in Autocad files.
Thanks in advance for help...
Thu, Feb 23, 2012 at 9:43:34 AM | Revit Exports DWG Sheet to 0,0,0 not correct coordinates.
In addition to that article, Read this topic in your HELP and the sub-topics:
Shared Positioning
Sheet DWG exports appeat PINK in autocad
Wed, Apr 10, 2013 at 7:54:45 AM
Exporting sheets to dwg with shared coordinates
Tue, May 6, 2008 at 9:50:37 PM
Shared Coordinates while linking Dwg into Rvt
Thu, Jun 5, 2014 at 12:06:32 PM
Sharing dwg Coordinates - Revit 2010
Wed, Jul 29, 2009 at 11:38:47 AM
Easting Northing Coordinates all "wrong"? (2010)
Wed, Sep 15, 2010 at 2:44:37 PM
Page generation time: 1.4417
