Forums >> Revit Structure >> Technical Support >> Tagging Bottom of wall elevations in plan?
Wed, Nov 23, 2011 at 1:24:42 PM | Tagging Bottom of wall elevations in plan?
jf20spiker
We typically show a bottom wall eleavtion in our plans.  Is there a way to create a tag or spot elevation that will show the actual elevation so I don't have to use the dinosaur method of inputing text?
Thanks
Joseph F
BIM Coordinator
Thu, Nov 24, 2011 at 8:14:10 AM | Tagging Bottom of wall elevations in plan?
You need a model element that resides at that elevation for you to tag with an elevation marker.
Mon, Nov 28, 2011 at 8:07:05 AM | Tagging Bottom of wall elevations in plan?
jf20spiker
The wall is a model element?  I just need to tag the bottom of it, but it's not available.
Joseph F
BIM Coordinator
Spot Elevations In Plan
Mon, Aug 7, 2006 at 5:14:23 PM
Revit door families
Fri, Jul 18, 2014 at 4:31:44 PM
IS IT POSSIBLE TO SPOT ELEVATIONS OF A WALL IN A FLOOR PLAN?
Tue, Jan 25, 2011 at 1:25:12 PM
Spot elevations
Thu, Apr 5, 2007 at 12:01:36 PM
Elevation marks Top and Bottom
Mon, Apr 20, 2015 at 4:57:40 PM
Page generation time: 2.5050
