Forums >> Revit Building >> Technical Support >> Dimension Question
Tue, Nov 22, 2011 at 6:07:34 AM | Dimension Question
StaticDOS
Hi guys, another simple question apologies, IM tring to dimension 2 points on the same wall but aligned dimension wont work as it only lets me dimsion the face of walls and not points in walls and since the wall is not at a right angle to the adjoining wall the dimension wont be correct, ive included a PDF of the 2 points I need to dimension. Thanks
Dell Precision T1500 Intel(R) Core(TM) i5 CPU 660 @ 3.33GHz Installed Memory 4.00 GB
Tue, Nov 22, 2011 at 6:23:05 AM | Dimension Question
Simply start your dimension and tab until you get the point at those intersections.
Tue, Nov 22, 2011 at 6:47:42 AM | Dimension Question
StaticDOS
I can pick up the first point of the wall but not the second point
Tue, Nov 22, 2011 at 9:35:31 AM | Dimension Question
You have to tab select at both points/
Tue, Nov 22, 2011 at 10:39:35 AM | Dimension Question
StaticDOS
I did that but the dimension is wrong because the adjoining wall is not perpendicular to the wall I want to dimension so I end up with a dimension like the one in the image, I had to hide the adjoining wall then dimension the wall then unhide the adjoining wall.
Tue, Nov 22, 2011 at 10:45:45 AM | Dimension Question
You have not used the process I described.   You have to tab select the point at each end.  You started with a face - not a point.  Try it again.
Edited on: Tue, Nov 22, 2011 at 10:46:10 AM
Tue, Nov 22, 2011 at 11:00:25 AM | Dimension Question
StaticDOS
Hi thanks I got it eventually after hitting the tab button about 50 times and putting on a pair of binoculars so I could see the dot
Tue, Nov 22, 2011 at 11:07:37 AM | Dimension Question
LOL - You missed the dot 48 times.... black background I bet....
Edited on: Tue, Nov 22, 2011 at 11:08:50 AM
Tue, Nov 22, 2011 at 11:13:33 AM | Dimension Question
StaticDOS
LOL no I only use a black background when usinf AutoCAD, the joys of learning Revit.
Wed, Nov 23, 2011 at 11:16:54 AM | Dimension Question
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Not a useful method for dimensioning that kind of thing in any case, how is someone to build with that kind of dimension. You should use a string with offsets.
Wed, Nov 23, 2011 at 11:41:34 AM | Dimension Question
#11
Lucius4
here is what I would have done
"Simple" dimension question?
Fri, Feb 29, 2008 at 9:48:32 AM
DIMENSION QUESTION
Wed, May 9, 2007 at 9:35:52 PM
Prefix in dimension style
Thu, Dec 16, 2010 at 9:15:11 AM
Question about Dimension Linetype
Fri, Oct 19, 2007 at 7:20:43 AM
Revit Boxed Dimension
Tue, May 8, 2018 at 8:24:43 AM
Page generation time: 2.9561
