Forums >> Revit Systems >> Tips & Tricks >> How do you hide the joint lines between different object (beam and wall) in elev
Tue, Nov 22, 2011 at 1:37:07 AM | How do you hide the joint lines between different object (beam and wall) in elev
maheshd
How do you hide the joint lines between different object (beam and wall) in elevation-revit.
so that it looks uniform surface
Tue, Nov 22, 2011 at 3:30:34 AM | How do you hide the joint lines between different object (beam and wall) in elev
Thread Post Kudo! #2
4 Stars: 205 Votes
In that elevation view try with "Join Geometry" tool or with "linework" tool with "Invisible lines"
Wed, Nov 23, 2011 at 12:11:14 AM | How do you hide the joint lines between different object (beam and wall) in elev
maheshd
thanx dude
Wed, Oct 30, 2013 at 1:40:49 AM | How do you hide the joint lines between different object (beam and wall) in elev
yosab
thank you very much, i was looking for that !
Fri, Feb 12, 2016 at 4:23:12 PM | How do you hide the joint lines between different object (beam and wall) in elev
Crazygirlzizou5
The linework tool is magic sent from the heavens!!
Tue, Mar 8, 2016 at 12:18:36 AM | How do you hide the joint lines between different object (beam and wall) in elev
Fairviewdental
I dont know about. Thanx
Bonnie Binau
Mon, Apr 25, 2016 at 2:42:56 PM | How do you hide the joint lines between different object (beam and wall) in elev
marmiketin1
4.5 Stars: 10 Votes
Linework tool is definitely prefered however in some cases it cannot be used (mostly with certain topography lines). Another sort of cheaty way is to override graphics and change the line weight to 1 and colour to white.
How do you hide the joint lines between different wall types?
Fri, Nov 16, 2007 at 8:16:34 AM
How do you hide different material joint lines?
Thu, Sep 15, 2011 at 6:53:41 AM
Hide joint lines in 3D and elevations
Thu, Sep 6, 2012 at 4:08:47 PM
Creating joint lines!!??
Mon, Mar 27, 2006 at 10:59:33 AM
Hiding A Beam System
Wed, May 7, 2014 at 11:28:53 AM
Page generation time: 0.8806
