Forums >> Revit Building >> Technical Support >> window thickness
Wed, Dec 7, 2005 at 10:31:46 AM | window thickness
Nathan
4.5 Stars: 3 Votes
I am trying to place a window on a 100mm wall and am getting the following msg: Can't make type "UK_Mdrn Casemt - Plain Sgl : 900 x 1350mm Deep 3". I figure the wall is not thick enough to place the window. If this is the case could someone let me know how to reduce the thickness of the window so it would fit, or let me know if there is something else I am doing wrong.
Wed, Dec 7, 2005 at 12:20:16 PM | RE: window thickness
ATisue
it might just be that your wall is not tall enough for the designated sill height of the window....check your window properties to make sure the sill height (and therefore the window) falls within the height of your wall. HTH
Thu, Dec 8, 2005 at 4:30:04 AM | RE: window thickness
Nathan
4.5 Stars: 3 Votes
No Id ont think it is. It seems fine. I replaced the wall with a thicker cavity wall and it works fine so there is something wrong with the thickness I believe. Do you know how to change this
Thu, Dec 8, 2005 at 8:03:01 AM | RE: window thickness
fazerneil
4 Stars: 5 Votes
Nathan, you will need to open up the window family for editing and look at all the parameters. Start in settings, family types and work your way from there. The window family may have been created with one default that does not suit a wall below a certain thickness ?
Thu, Dec 8, 2005 at 9:45:56 AM | RE: window thickness
Rythmick
5 Stars: 2 Votes
You can cut and paste the wall type from your project browser into the window family editor to work with it and make corrections in the family. Once you paste it into the editor you need to select the wall then make the change.
Thu, Dec 8, 2005 at 5:16:03 PM | RE: window thickness
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
In the family select the wall and got to its structure and change its thickness to the same in your project. At this time you'll receive a number of constraint errors. This is why the family isn't working in the project. Try to unconstrain these items and amend so you can flex the wall thickness without errors. HTH.
Revit 2013 - Window frame sweep with wall thickness
Wed, Nov 28, 2012 at 4:03:26 AM
Window wont place in wall of different thickness
Wed, Mar 16, 2011 at 7:19:27 AM
Wall Thickness in Type Parameter
Fri, Jun 1, 2018 at 7:39:15 AM
Muntin Thickness
Wed, Aug 12, 2009 at 3:13:33 PM
parametric window should recognize wall type!
Wed, Apr 12, 2006 at 7:44:20 AM
Page generation time: 1.2506
