Forums >> Revit Building >> Technical Support >> Problem selecting glass using tab key
Mon, Nov 21, 2011 at 5:44:06 PM | Problem selecting glass using tab key
m1g2d
Hi there,
I am trying to select a glass element from a curtain wall. I have added mullions around the glass panels and am unable to select the glass panel. I hover around the mullion and then I press the tab key to cycle through the various selection and then after it highlights the glass panel I right click on my mouse but then for some reason the object doesnt get selected. I must be doing something wrong or I am beginning to suspect my video card might be the culprit. I have an ati 4400 series (more or less) running quad amd. Please help. Thank you .....your help much appreciated.
Mon, Nov 21, 2011 at 7:03:13 PM | m1g2d
gulliver49
Quoting m1g2d from 2011-11-21 17:44:06
Hi there,
I believe you should left click once the glass panel is highlighted. At least I think that's the problem here.
Mon, Nov 21, 2011 at 7:14:13 PM | Problem selecting glass using tab key
m1g2d
Thanks for your reply. sorry, I did left click but for some reason it doesnt get selected. i try to pre-highlight an object and press tab to choose adjacent objects and after I click the object (hoping everything would get selected) only the object i clicked gets selected. I am closely following a tutorial and I thought selecting would be so straight forward but for some reason I am running into problems. thanks.
Mon, Nov 21, 2011 at 7:46:29 PM | Problem selecting glass using tab key
m1g2d
I don't seem to have the same problem in another machine. This is driving me crazy and I'll just blame this on my ati graphics card until I find a suitable response from someone. cheers!
Mon, Nov 21, 2011 at 8:23:36 PM | Problem selecting glass using tab key
m1g2d
For the interest of anyone who might stumble the same problem. I managed to fix the problem by updating my video card. Now it's working fine. Thanks.
Thu, Mar 21, 2019 at 1:17:37 PM | Problem selecting glass using tab key
acalverley
Just learned this so thought I'd give another reply in case someone else is searching this out -
The 'Select Pinned Elements' option is turned on/off. Try clicking on the little push-pin with a cursor symbol over it on the bottom-right corner. If a red X is shown, you can not select any pinned elements and that would include a panel in a curtain wall system by default.
RCP - Problem selecting
Fri, Aug 13, 2010 at 2:44:32 PM
Revit crashes whenever I hit CTRL + Tilde key
Tue, Dec 7, 2010 at 7:19:36 PM
Curtain wall: Change the glass colour?
Fri, Aug 27, 2010 at 10:13:57 AM
External Glass Curtain Panel Problem
Tue, Aug 12, 2014 at 8:05:34 AM
Revit Walkthrough; between key frames
Thu, Jul 30, 2015 at 8:22:01 AM
Page generation time: 0.6308
