Forums >> Revit Building >> Technical Support >> Parametric grips and conceptual mass questions
Mon, Nov 21, 2011 at 5:25:52 PM | Parametric grips and conceptual mass questions
gulliver49
Hi,
I had a question about families. Some families I download from this site can be altered in plan view. They have arrow grip boxes that let me adjust the size without having to go into edit family. How can I get those grips for families that I make?
I also had a questiona about conceptual masses. I have only been able to add edges on vertical surfaces, when I try to put an edge on a horozontal surface, revit won't let me. Any ideas on why this is?
Thanks in advance.
Tue, Nov 22, 2011 at 3:37:39 AM | Parametric grips and conceptual mass questions
4 Stars: 205 Votes
1. - When you create a family use "Ref. planes" and attach/align the geometry to those ref.planes and if those parameters are "INSTANCE" param. you'll have those arrows grip.
2. - "when I try to put an edge on a horozontal surface, revit won't let me" - NO, you need to add a "Profile" not an edge (if i'm not misunderstood the question...)
Tue, Nov 22, 2011 at 5:04:29 PM | Parametric grips and conceptual mass questions
gulliver49
Thank you Typhoon. I managed to get the grips now.
As for the conceptual mass issue, I've managed to get profiles on just fine, but edges I can't. I'll upload some pictures tomorrow to show what I'm talking about. I'll try to upload the file too if I can.
I also can't put edges on objects that are curved. Once I post pictures I'm sure you'll see what I'm doing wrong.
Wed, Nov 23, 2011 at 4:09:33 AM | Parametric grips and conceptual mass questions
4 Stars: 205 Votes
"I'll try to upload the file too if I can. I also can't put edges on objects that are curved. Once I post pictures I'm sure you'll see what I'm doing wrong." - Go ahead, show me the "money" and will see if we can help you. Smile
Wed, Nov 23, 2011 at 12:40:58 PM | Parametric grips and conceptual mass questions
gulliver49
Here's the file and some pics of what I'm having trouble with.
I can add an edge to the sides of the seat, but not to the top of the seat. And I can't add edges to the whole backrest. Profiles are okay though.
Wed, Nov 23, 2011 at 1:13:01 PM | Parametric grips and conceptual mass questions
4 Stars: 205 Votes
Select the object, click on "Dissolve", select again those lines and click on "create form" now you can add the edges.
CONCEPTUAL MASS RAC2011
Fri, Jan 21, 2011 at 1:54:12 PM
conceptual mass problem
Fri, Jan 13, 2012 at 4:02:05 PM
conceptual mass -newbie to that
Mon, Feb 21, 2011 at 9:21:36 AM
Scaling Conceptual Mass
Mon, Oct 11, 2010 at 7:34:51 AM
Update Structural Framing with Updated Conceptual Mass?
Thu, Mar 12, 2015 at 6:54:55 PM
Page generation time: 7.6614
