14 Users Online (12 Members):
Forums >> Revit Systems >> Technical Support >> Elevation of receptacle with formula
1 Posts No Rating |
Our company standard for receptacle annotation is with half of the circle filled in. I'm trying to use a formula so that if the elevation is higher than a default of 1' 6", the the annotation shows this half filled in circle. I have associated the filled in part with a visibility parameter.I've tried using the formula Elevation > 1' 6", but I get an error message saying that Elevation is not a valid parameter.I've also tried creating a seperate ElevationReceptacle parameter, but this means that I have to change the heigth of the receptacle in two places, one for the annotation and one for the 3D geometry. My skills are not good enough to associate the 3D geometry with the new parameter and the changes in the wall placement.I have attached a couple of screen clips. One showing model properties and one showing family parameters. The red receptacle is the way I want it to look when I change the elevation of the outlet.I have also attached the receptacle family. Don't get too critical with some parts. It's still a work in progress.
Thanks,
Rabbit
Rabbit,
I opened that file, but it looks like the floorplan shows the receptacle in elevation and the elevation shows the symbol in the floor plan....did you mean to do it like that?
**Using Revit Architecture 2009, 2011, and 2012** |
Receptacle Tags |
Mon, Jan 7, 2013 at 3:12:44 PM
Elevation Formula |
Wed, Apr 8, 2009 at 11:07:26 AM
HELP! Elevation issues? |
Thu, May 5, 2011 at 12:54:15 PM
Building Electrical Content |
Thu, May 17, 2007 at 7:51:26 PM
Ceiling Mounted Receptacles |
Mon, Mar 19, 2012 at 12:09:47 PM
