Forums >> Revit Building >> Technical Support >> Shading Structural Walls
Mon, Nov 21, 2011 at 9:51:51 AM | Shading Structural Walls
AlphaOjo
Is it possible to create a view template where the cut pattern of structural walls is shaded differently than other (non-structural) walls?  In Visibility/Graphic overrides, there doesn't seem to be any way to distinguish between structural/non-structural walls...just walls as a whole.
I know I can do overrides by elements, but that will take a long time given all of the different walls and drawings I have and I would like to create a usable template so that I can have hatched structural walls and all others as just white.  Any ideas?  Thanks.
Mon, Nov 21, 2011 at 10:17:14 AM | Shading Structural Walls
You could set up your wall types accordingly.  Structural walls would have coarse fill pattern.
Mon, Nov 21, 2011 at 11:17:31 AM | Shading Structural Walls
AlphaOjo
I'm not sure I follow 100%.  Is it possible to have a view template that makes all walls poche solid black, but then one type of wall that overrides this with a different fill pattern?
Mon, Nov 21, 2011 at 11:21:46 AM | Shading Structural Walls
Reread my post.  I talked about wall type settings & coarse fill pattern.
viewing structural, architectural & hvac in 3d with shading and edges
Tue, Apr 20, 2010 at 5:53:58 AM
Shading w/ Edges Color Differences
Thu, Jul 23, 2009 at 2:18:43 PM
structural usage for stacked walls
Tue, Jun 30, 2015 at 6:59:56 PM
Shading Colour
Mon, Feb 15, 2010 at 4:47:51 AM
Wall Materials and shading.
Fri, Jan 30, 2009 at 4:01:22 PM
Page generation time: 0.3597
