Forums >> Revit Building >> Technical Support >> Components
Wed, Dec 7, 2005 at 9:49:35 AM | Components
Midget999
How do you put color into components for rendering? Post edited on 2005-12-07 09:49:51
Wed, Dec 7, 2005 at 11:53:18 AM | RE: Components
TomDorner
4.5 Stars: 25 Votes
Rendering is done by assigning a Revit material to an Accurender material which is in turn assigned a procedural or bitmap image. If your component is a pure Revit object then the help file should cover this. If the object is based on a DWG object then their is a tutorial on this site as well for those types of objects. You are going into a complex world when it comes to rendering and I would suggest going through the tutorials and reading up on the subject. Tom
Components on Level are Grey
Wed, Apr 17, 2013 at 12:56:06 PM
problem loading components
Sun, Apr 26, 2009 at 2:21:18 PM
transferring components
Tue, Jul 29, 2008 at 3:51:00 AM
Visibility/Graphics and Detail Components
Wed, Feb 23, 2011 at 2:53:36 PM
deleting old components
Sat, Apr 11, 2009 at 12:28:12 PM
Page generation time: 0.6799
