Forums >> Revit Building >> Technical Support >> Lighting in shelving units
Fri, Nov 18, 2011 at 8:23:53 PM | Lighting in shelving units
cshroyer
Hi:
I am building shelving units in Revit and wanted to put recessed can lighting in the top of each one.  How do you do this? Which family file would I need to use?
I built a shelving unit in the Lighting Fixture file, but when I tried to put in any lighting, it didn't work. What do I need to do?
I'd appreciate any answers!
Thanks!
Sat, Nov 19, 2011 at 7:22:50 AM | Lighting in shelving units
4 Stars: 205 Votes
Go to your library and check your "lighting fixtures" folder, select one BUT you can't use "Ceilings or Wall" based families because you didn't created those shelvings with walls or ceilings right?
Sat, Nov 19, 2011 at 9:16:41 AM | Lighting in shelving units
You need a face based light fixture.
Scheduling Nested Families
Mon, Mar 9, 2020 at 11:15:10 AM
Lighting Units not Rendering
Mon, Nov 9, 2015 at 7:03:00 PM
14
SHELVING SYSTEM
Fri, Nov 28, 2008 at 9:32:55 AM
Yes/No paramter controlled by two different types of paramters
Thu, Mar 13, 2014 at 11:58:39 AM
Conversion from English Units to Metric Units
Tue, Feb 17, 2009 at 4:32:52 AM
Page generation time: 0.1396
