Forums >> Revit Building >> Technical Support >> 2D Element into 3D Family
Fri, Nov 18, 2011 at 10:54:37 AM | 2D Element into 3D Family
StaticDOS
Hi guys quick question, how do I bring a 2D element into a 3D family anf extrude it and turn it into a 3D object? I keep getting an error message when I try 2 load it or copy it into my family drawing.
Dell Precision T1500 Intel(R) Core(TM) i5 CPU 660 @ 3.33GHz Installed Memory 4.00 GB
Mon, Jan 2, 2012 at 2:15:30 PM | 2D Element into 3D Family
e00878
I would recommend you to try to insert this 2D lines drawing as dwg file.
http://www.revitwatch.com
Mon, Jan 2, 2012 at 2:16:20 PM | 2D Element into 3D Family
e00878
then draw over with revit model elements
Tue, Jan 3, 2012 at 9:07:03 AM | 2D Element into 3D Family
First, understand that all extrusions have to be closed objects and the definition lines can not cross.  That being said, import your CAD and pick lines to define each seperate extrusion (or whatever).
family element render materials [ 1 2 ]
Sat, Feb 14, 2009 at 10:47:01 AM
17
deleted element family error
Thu, Nov 6, 2008 at 12:00:02 PM
Family Element ID's
Thu, Jul 2, 2009 at 11:19:17 AM
switching element type to curtain element error
Wed, Nov 16, 2011 at 1:37:03 PM
Creating a Family
Tue, Feb 14, 2017 at 1:20:39 PM
Page generation time: 4.5158
