Forums >> Revit Systems >> Technical Support >> Revit MEP 2011 sloping ductwork by default?
Thu, Nov 17, 2011 at 3:49:26 PM | Revit MEP 2011 sloping ductwork by default?
balkanbase
My company just started using MEP 2011, so we're all kind of new to this and nobody knows what's going on.
When i draw ductwork, regardless whether it's rectangular or round, it will either slope it on a long run, or transition the height automatically after 1-2 elbows. When I try to lock the specified elevation (for example elevation of exhaust fan duct outlet), revit will 1-2 turns later place all the ductwork to another random elevation and won't connect to the exhaust fan.I tried drawing within the building and connecting equipment, as well as way off the grid randomly in space, and am having the same issue. Even in blank space, it won't draw a duct with 1-2 turns that stays at let's say 9ft start to finish.
Any helpful hints are greatly appreciated.
REVIT MEP 2012 Ductwork Connection to Sidewall Diffuser
Wed, Mar 20, 2013 at 3:31:59 PM
Using Revit MEP to make ductwork shop drawings
Wed, Jun 15, 2011 at 9:52:02 PM
How can I create calculated sloping ductwork, with elbows?
Sun, Feb 18, 2018 at 3:12:08 AM
Shading Ductwork and Air Terminals on plan
Tue, Oct 19, 2010 at 3:08:32 PM
Linked MEP Ductwork not being cut
Wed, Feb 13, 2013 at 9:06:06 AM
Page generation time: 1.6346
