Forums >> Community >> Newbies >> Vynil Porch Post
Thu, Nov 17, 2011 at 2:49:03 PM | Vynil Porch Post
spassero
Does anyone know why Revit will not let me put a vinyl 6x6 porch post onto a two stroy porch? I can easily put one on the front story portion, but it will not let me put a couple on the second story to hold up the roof. I've checked all constraints and can find nothing out of the ordinary.
Thu, Nov 17, 2011 at 3:26:48 PM | Vynil Porch Post
The post is probably hosted.  See if you can change the properties of your first floor post to be scond floor.  If it moves, you should be able to figure it all out from there.
Thu, Nov 17, 2011 at 3:30:30 PM | Vynil Porch Post
spassero
I tried that...it tells me that it can't be done...it's wierd I can put this post onto anything level first floor or below...but when I try and put it anywhere above that the program says no good.
Thu, Nov 17, 2011 at 3:38:15 PM | Vynil Porch Post
Would need to see the family.
Thu, Nov 17, 2011 at 3:48:16 PM | Vynil Porch Post
spassero
Here is the rfa...thank you for your response...I've got a Tuesday deadline and this is really holding me up.
Fri, Nov 18, 2011 at 8:05:07 AM | Vynil Porch Post
That is a BAD family.  I don't really have time to investicate it fully but they buried some constraint in there somewhere.  You need to rebuild this family.
porch stairs
Thu, Sep 9, 2010 at 4:20:46 PM
screened in porch
Fri, Dec 23, 2005 at 12:21:38 PM
Front Porch Overhang
Sat, Feb 27, 2016 at 11:08:02 AM
Downloaded the Porch of this site, how to insert?
Fri, Nov 30, 2007 at 10:56:57 AM
trying to build custom trim treatment for porch/entry area
Sat, Sep 3, 2016 at 10:26:37 PM
Page generation time: 1.1421
