6 Users Online (4 Members):
Forums >> Community >> Newbies >> Noob Question
8 Posts No Rating |
I need to create a transaction top that seems best to create with a profile (section view), but I need to edit it from the plan (ref) view. When I edit extrusion, it pops back to the profile. How do I keep it an extrusion so I can miter the corners as needed?
I have the best Revit education U-tube can offer...
Thanks in advance....
If you need to turn a corner and you want a profile, you need a sweep with the path set in plan.
8 Posts No Rating |
If I use a sweep, will it affect the BIM? I am a long way from dealing with BIM issues, but I want to prevent issues down the road.
Thank you for your quick response
You can build this in the family editor or in the project as in-place. In either case, you can use a sweep and set the category correctly.... It will schedule and it can tag both by category, material or keynote if you set all of those. So yes, it is still BIM even if it is a sweep.
noob question on massing |
Mon, Jun 2, 2008 at 12:33:38 PM
Noob question: Revit to 3D Max question |
Sun, May 1, 2016 at 8:29:31 AM
Noob question about uploading models |
Fri, May 30, 2008 at 10:31:05 AM
Noob Question - Why can't I select concrete as a Wall type (arch)? |
Sat, Mar 23, 2013 at 8:34:35 AM
Roof question |
Mon, Apr 28, 2008 at 1:30:48 PM
