12 Users Online (10 Members):
Forums >> Workflow & Implementation >> Training >> Dimension aligned
43 Posts No Rating |
I think I am not the first with that question , but how to make a aligned bimension between 2 angular walls , dimesion must be aligned to one of the wall or only to the points , or to make a line that intersects all the walls and align dimesnions to that line, but if i will delete that line , the dimension line must stay, a kind of nonasociated dimension, only through points.a dimension that is aligned only to selected points, like in autocad... detail line helps but how to make it invisible ...
A couple of tricks:
- Use your tab key to select a point instead of a line/face. The point must be an intersection or the end of a line.
- Draw a temporary line perpindicular to what you are dimensioning. Start your aligned dimension using that line then dimension both ways and complete the dimension. Delete the line.
but when i delete the line the dimensions are deleted too, yes with tab key I select the intersections
One dimension - not two.... A continuous dimension.
You should use continuous dimesions whever possible.
How to make an aligned dimension? |
Wed, Dec 11, 2013 at 5:19:54 AM
Aligned dimensions on non-orthogonal walls |
Sun, Jun 11, 2006 at 8:16:11 PM
Aligned dimensions |
Wed, Apr 12, 2006 at 3:22:31 PM
Using Aligned dimension to manipulate a square to perfect specifications???????? |
Mon, Sep 23, 2013 at 8:00:53 AM
DIMENSION QUESTION |
Wed, May 9, 2007 at 9:35:52 PM
