Forums >> Revit Building >> Technical Support >> Split face on floor?
Wed, Nov 16, 2011 at 7:36:59 PM | Split face on floor?
gulliver49
My objective is to create an intricate tile pattern on the floor using different shapes and colors. If I could use split face and paint, my job would be done.
Is it possible to use the split face command on the floor? As of now, revit won't let me.
Wed, Nov 16, 2011 at 7:42:24 PM | Split face on floor?
I believe I have used it in the past but not yet in 11 or 12.  I'll check it out tomorrow.
Thu, Nov 17, 2011 at 4:38:44 AM | Split face on floor?
4 Stars: 205 Votes
Did you tried?
Thu, Nov 17, 2011 at 7:26:01 AM | Split face on floor?
Yep ... still works for me....
Thu, Nov 17, 2011 at 2:28:26 PM | Split face on floor?
gulliver49
Yep I tried. No good.
I'm in the floor plan view, I go to the modify tab, select split face, and try to click on the floor slab I have, and it won't select it. It will select the walls though...
I can provide screen shots, or if you all need any info let me know. I REALLY don't want to place a seperate floor slab in every section of the floor that I want a different color.
Edited on: Thu, Nov 17, 2011 at 2:31:10 PM
Thu, Nov 17, 2011 at 2:41:46 PM | Split face on floor?
You can't select anything from the middle..... must be an edge.  << That is probably your problem. If your floor goes under your walls, the wall edge is not the floor edge.  Also make sure you actually have the floor on in VG.
Sat, Nov 19, 2011 at 7:05:17 AM | Split face on floor?
gulliver49
I just checked and yes that's what I was doing wrong! Thank you for your help!
Wed, Nov 18, 2015 at 12:15:46 PM | Split face on floor?
Paolini
Hello everybody. I give new life to this conversation to ask about a problem I have. I'm trying to split the surface of a floor, and I have no problems until I modify the secondary elements of the floor: if the floor has a curved side, Revit won't let me split it.
Any suggestion?
Thank you in advance
Wed, Nov 18, 2015 at 1:16:28 PM | Split face on floor?
You are correct, Revit doesn't seem to permit that.
We don't use split face anymore for floors.  We place a very thin floor on top of our floor for finish elements like tile / wood.
Split Face Sketch on Floor Completes then Displays Error: Line is Too Short
Wed, May 22, 2013 at 3:12:37 PM
Split face for multi colored wall
Wed, Oct 7, 2020 at 3:18:11 PM
SPLIT FACE BLOCK
Tue, Jul 18, 2006 at 10:41:24 AM
editing split face boundaries
Wed, Jun 4, 2008 at 9:43:18 AM
12
Edit Split Face on Ceiling
Mon, Jan 25, 2010 at 4:42:26 PM
Page generation time: 0.7284
