Forums >> Revit Building >> Technical Support >> Concrete panel
Wed, Dec 7, 2005 at 12:29:17 AM | Concrete panel
shaun_kiwi
5 Stars: 2 Votes
We wish to cut concrete panels and have the steel visable. Detailing many of them at the moment and wish to make a few generic ones. We tried making them various things I.E casework, structural columns etc. The hatches get all screwed up. Any easy solution?
Wed, Dec 7, 2005 at 5:01:20 AM | RE: Concrete panel
eldados
eldados Avatar
4.5 Stars: 8 Votes
do you want to use them as walls or just as an external family? you can create it as a generic model, extruded with parameters to control width and height, thickness... use extrusion for the steel pocking out, have a look at Mr. Spot's tutorial for nested array, will give you an idea Smile Good luck HTH
Integrator
KarelCAD
Wed, Dec 7, 2005 at 2:36:35 PM | RE: Concrete panel
Rythmick
5 Stars: 2 Votes
I would try and create the rebars as a sweep. Are you looking at a grid pattern or ? You could add the sweeps within the wall editor if it's the same in each panel.
Dimensioning a concrete panel w/ openings in elevation view
Tue, Mar 25, 2008 at 3:07:22 PM
Smart Tags - Cast In Place Concrete Panels
Thu, Sep 12, 2013 at 8:41:32 AM
Tilt Panel Concrete Walls
Thu, Nov 30, 2017 at 9:53:05 PM
Getting my drop panel to show up with hidden lines correctly
Thu, Mar 22, 2007 at 9:53:53 AM
Concrete panel 'tilt ups'
Thu, Oct 30, 2014 at 8:11:10 AM
Page generation time: 0.1740
