38 Users Online (36 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Split Face Line appearance
Wed, Nov 16, 2011 at 12:30:21 PM | Split Face Line appearance
cmelande
I am creating a exterior wall with a metal panel material that has an irregular pattern to it.  So I have used the split face tool to slice the wall up into different sections with the pattern that I want.  However, I cannot find what controls the appearance of those lines.  I don't see it in the object styles dialogue box.  Is there something I am missing?
[cm]
Wed, Nov 16, 2011 at 1:14:21 PM | Split Face Line appearance
The line is not controlled when you place it but afterwards, you can use the linework tool on it.
Split face boundaries - visibilty control
Wed, Jan 21, 2009 at 9:51:25 PM
Split face for multi colored wall
Wed, Oct 7, 2020 at 3:18:11 PM
Split face aournd a corner...
Tue, Aug 25, 2009 at 2:14:22 PM
Edit Split Face on Ceiling
Mon, Jan 25, 2010 at 4:42:26 PM
Split face pattern line weight (2009)
Tue, Aug 19, 2008 at 2:57:25 PM
Page generation time: 0.4299
