Forums >> Revit Building >> Technical Support >> Door Hardware
Wed, Nov 16, 2011 at 5:56:16 AM | Door Hardware
StaticDOS
Hi guys, im drawing a Custom Door Family and I want to put a pull handle into the model but cant seem to find any, does revit 2011 come with door hardware components? I cant seem to find any in the libraries folder. Also I want to do a door schedule showing number of hinges, fire raring etc. can I add all these in the Door Template or can I only add those when I bring it into the project. Thanks
Dell Precision T1500 Intel(R) Core(TM) i5 CPU 660 @ 3.33GHz Installed Memory 4.00 GB
Wed, Nov 16, 2011 at 7:27:32 AM | Door Hardware
"...does revit 2011 come with door hardware components?"  No - Most of us do not model hardware except possibly for pulls.
"... I want to do a door schedule showing number of hinges, fire raring etc. can I add all these in the Door Template ?" You could add to the template if you want but you don't need to.  Set up a shared parameter file with these items and add to your families.
You could also make these a project level parameter and just add them in the project template - category doors.  But you still need them in a shared parameter file.
Door Hardware
Thu, Nov 23, 2017 at 11:05:24 AM
Door hardware Schedule
Fri, Dec 2, 2011 at 11:01:22 AM
Door Hardware and Accessories
Thu, Mar 29, 2007 at 8:33:27 AM
Door Hardware and accessories
Wed, Mar 28, 2007 at 10:15:46 AM
Door schedule
Sat, Nov 8, 2014 at 7:47:17 AM
Page generation time: 0.2775
