Forums >> Revit Building >> Technical Support >> Wall cut
Tue, Dec 6, 2005 at 8:47:35 PM | Wall cut
puzzle
4 Stars: 10 Votes
I have a wall that goes from the first floor up to the 2nd floor ceilng. Is there a way to cut that wall at the 2nd floor level as I need to change the upper wall to another wall thickness but I don't want to have to delete all the windows. Appreciate any help. Puzzle
Macca
Sunshine Coast
QLD Australia
Tue, Dec 6, 2005 at 11:37:40 PM | RE: Wall cut
eldados
eldados Avatar
4.5 Stars: 8 Votes
not sure i understand... go to elevation and split the wall, 9dosent need to be accurate, you can adjust later) and change the top to what ever wall you want... HTH
Integrator
KarelCAD
Wed, Dec 7, 2005 at 12:46:12 AM | RE: Wall cut
puzzle
4 Stars: 10 Votes
Thanks, somethings are just to simply. Puzzle Sunshine Coast
Macca
Sunshine Coast
QLD Australia
How Do I Cut Out Part Of The Wall?
Wed, Apr 22, 2009 at 5:30:18 PM
5'8" wall will not be cut by cutplane
Mon, Nov 13, 2017 at 3:49:59 PM
Diagonal End of Wall - Void + Cut Geometry not working
Fri, Aug 30, 2013 at 3:25:08 AM
Void Cut Through Integrated Wall Sweep for Downspout
Tue, Sep 16, 2025 at 7:50:28 AM
wall cut lines not displaying
Fri, Sep 19, 2008 at 3:31:05 AM
Page generation time: 3.0195
