11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Manipulate Structural Grid in Architectural model
Revit 2011, Architectural and Structural
I've imported the structural model into my architectural model. The structural grid in their model has the grid bubbles adjusted so that they don't overlap (with the little elbow jog); this only shows up in the structural model. When the grid comes into the architectural model, the elbows are gone and bubbles are overlapping; I can't find any way to correct this.
Does anyone have any suggestions?
Thanks!
Use Copy/Monitor to make your own grids (that you have complete control over), hide the structural grids.
You should copy monitor the grids, then turn off the structural grids in VG. Now you can adjust the grid bubbles as you need.
Perfect! Thanks for your help.
Same goes for Levels.
Best Practices - Coordinating Column Grids Across Arch. and Structural Models |
Wed, Nov 11, 2009 at 9:32:25 AM
visibility of reinforcing from linked structural model in architectural sections |
Thu, May 29, 2008 at 3:44:37 PM
Architectural Vs. Structural Linking |
Tue, Feb 19, 2019 at 10:42:28 PM
Linking structural model to architectural model |
Tue, Oct 9, 2007 at 6:05:11 PM
hide architectural wall layers in structural views? [ 1 2 ] |
Fri, Apr 19, 2013 at 3:04:09 AM
24
