27 Users Online (25 Members):
Forums >> Revit Building >> Technical Support >> Family problems...with sections
Please see attached family & image from project
In R09 I made the family out of 3 separate families, lift car, lift shaft with door & an infill panel, the shaft is an array of the door panel & panel families. Now when I put this into a project the sections show up reversed for some reason!
I have checked the family file & the same happens in there too - no idea why, it all looks ok in 3D & plan but when you cut it it goes a bit mad, anyone got any ideas? Also my lift car's not showing up either which is slightly annoying. There are no masking regions at all. I have a feeling it has something to do with the array but I can't think what it would be! Arrg! hope this isn't a waste of a day!
Help appreciated!
Thanks!
OK, try agian with the photo...appologies if this doesn't work!
The problem may be the cuttable switch. When a non-cuttable family is cut anywhere, the whole family is shown.
Try setting the nested families to shared....
Thanks WWHub, but I just did a search agian & found out about the cuttable switch - I have never come across that before! Thanks for the advice, I'm going to change it & see what happes (and make a list of non-cuttable families for easy reference)! Cheers
view names in building sections are missing |
Wed, Apr 2, 2008 at 6:19:24 AM
Room tags At Sections |
Tue, Jun 12, 2007 at 2:46:10 PM
Telescoping pole family and chaning all 3 sections with adjustments issue.... |
Tue, Jul 18, 2017 at 10:28:40 AM
Sections Referencing the drawing you want. Help Cheat! |
Fri, Feb 25, 2011 at 11:22:05 AM
window cills making walls disappear in sections |
Tue, Feb 20, 2018 at 6:53:34 PM
