14 Users Online (12 Members):
Forums >> Community >> Newbies >> wall materials
39 Posts No Rating |
hi every one ,
im new at revit and i use 2012 i try to made different material to the same wall for exp: ihave wall in the first floor brick and in the ground floor concrete how can i sprit the levels at the model to add the material to each level
any suggestion please
thanks
They are not the same wall.... so treat them that way. Split the wall horizontally and assign the different wall types accordingly. You can also create a stacked wall type that does this for you. You can read about stacked walls in your HELP.
thanks , but i split the wall horrizontly but when i change the material to one of them the other one take the same material just like one wall
your question is pretty unclear...
do you maybe only have one wall type in your project to select from in the wall pull down? if so, create a new one by selecting the current wall, edit type, duplicate, give it a name, edit structure.
thank you so much that work great
Revit 2009: detailings: tag that list all wall's materials |
Mon, Oct 12, 2009 at 7:47:25 AM
Two Materials on a wall |
Thu, Jan 12, 2012 at 12:41:08 PM
Wall materials |
Thu, Oct 12, 2006 at 6:52:15 PM
Wall Types and Materials are not shown in Revit 2011 |
Mon, Apr 25, 2011 at 9:34:27 AM
Revit Wall materials |
Mon, May 5, 2008 at 1:58:45 AM
