22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> Annotation/Dimension
Hi all, I have a small annotation question, attached PDF shows a dimension to the Patio that has a leader and text in lieu of the actual dimension. I am using Revit Architecture 2012
Here is what I am trying to achieve
1. A family Dimension or Annotation that would show the extent of the notation with a normal straight leader
2. The abilty to alter the text as per normal eg size/ width of the area to place the annotation ( Like the handles on standard text)
3. Able to have multiple leaders to indicate the same note on 2 different walls at the same time.
I am happy to create a family to do this but I dont knw if it would be better to start as a dimnesion or annotation. Also where would I find a template to start with.
I realise this is more of a structural type question but I have the need for this type of notation more and more frequently
Any help would be greatly appreciated.
Regards
Shawn
When I need to do something like that, I usually just replace the dimension with the text "refer Note 1" (or whatever number/letter you like). Then write the notes on the same sheet or near the plan/drawing. Trying to squeeze in long/complicated notes into dimensioning always ends up looking like a dog's breakfast otherwise I think...
I know that doesnt solve your question directly, but maybe you dont need to do it the way you are thinking?
----------------------------------- www.aspectarch.com |
dimension annotation |
Mon, Feb 20, 2006 at 8:37:23 PM
Annotation in Dimension |
Wed, Apr 2, 2014 at 9:30:10 PM
flexing annotation |
Mon, Jul 13, 2009 at 11:16:08 AM
Dimension Line Weight |
Fri, Oct 7, 2016 at 1:32:52 PM
editing dimension line |
Wed, Apr 27, 2005 at 1:53:05 PM
