Forums >> Revit Building >> Technical Support >> rhino to revit
Sat, Nov 12, 2011 at 11:56:45 AM | rhino to revit
italianplaya2k3
hi everyone.  I have searched for a long time for an anaswer and have had no results.  i made a floor slab in rhino in imported to revit as a SAT file it comes in as a component.  when i go to add components to it such as toilets, chairs, ect it does not snap.  I am also having an issue with adding walls to the floor slab.  i do not think revit is recognizing my imported item as a floor slab and will not let me add walls to it.  any help would be appreciated.
Sat, Nov 12, 2011 at 1:50:20 PM | rhino to revit
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
recreate that floor within revit. Even if it has a slope, it can be done in revit. Can you upload some shots of what you want to do?
Sat, Nov 12, 2011 at 2:37:57 PM | rhino to revit
italianplaya2k3
what im trying to do is add stadium seating to the curves on that mass and somehow have my walls follow the curved floor slab.
Sun, Nov 13, 2011 at 12:44:56 PM | rhino to revit
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
We will use a "hackwall" then .... to makes things easier (is too hard creating one by one every single seat) .
And a lot of levels to locate the furniture and seats.
You create straight floors to get the correct intersection with the curved slab, and then create the seats with the curtain wall hack.
Check the attachment
Sun, Nov 13, 2011 at 8:12:34 PM | rhino to revit
italianplaya2k3
that is what i am attempting to do but can not follow your instructions in the revit document could you please explain in further deatail.  thank you every much.
Editing revit file in rhino.
Thu, Feb 13, 2020 at 5:19:48 AM
Revit to Rhino
Thu, Feb 13, 2020 at 5:22:39 AM
rhino
Mon, Aug 7, 2006 at 6:07:17 PM
Import Rhino model into Revit
Mon, Mar 3, 2014 at 7:42:36 AM
Rhino to Revit
Thu, Oct 30, 2008 at 4:45:23 AM
Page generation time: 1.5480
