Forums >> Revit Building >> Technical Support >> switching element type to curtain element error
Thu, Nov 10, 2011 at 2:35:24 PM | switching element type to curtain element error
mrutherford17
I have a window family placed right next to a curtain wall. I want to copy the window to levels above. Window will not copy and the following message apears "Switing element type to curtain element. All inserts in the element will be deleted."
Has anyone had this error before and found a solution?
Thanks very much
Thu, Nov 10, 2011 at 2:59:38 PM | switching element type to curtain element error
Not enough information.  If you are copying a window (not a CW) then you would not get a CW error message.
Thu, Nov 10, 2011 at 3:27:23 PM | switching element type to curtain element error
mrutherford17
The only other thing I can think of is that there are curtain walls on both sides of the window on both the level I am copying from and the levels I am copying to.
If anyone can think of something please let me know. Otherwise thanks anyway.
Thu, Nov 10, 2011 at 3:49:09 PM | switching element type to curtain element error
Ah - that is important.  Your CW on the upper level is interfering with this window and it is causing problems.  Set a referece plane in at the end of the CW where this window is and you should see the problem on the upper level.
Wed, Nov 16, 2011 at 7:55:42 AM | switching element type to curtain element error
mrutherford17
Thanks for your help, but I am not able to fix the problem. To clarify further what we are trying to do is place a spandrel panel curtain wall over an ICF wall construction as a rainscreen. So we want the curtain wall to cut through the brick but not the entire wall. Where we have a vision panels we want the curtain wall to cut through the entire wall.
The idea we were trying was to create a window family to replace the spandrel panels.
What we are doing now instead is seperating the brick from the ICF wall and having to manually cut out all of our vision panels.
Before anyone mentions to try and replace the panels with a wall within the curtain wall, we tried this and found that working with the mullion families to avoid cutting the wall was too much trouble.
If someone has a solution to this problem feel free to post for future reference, but we are moving forward.
Thanks again.
Wed, Nov 16, 2011 at 1:37:03 PM | switching element type to curtain element error
Why don't you just add openings where you want the cut in the main wall and don't join your curtain wall to the main wall?
Set your CW embed switch to off.
Edited on: Wed, Nov 16, 2011 at 1:37:40 PM
deleted element family error
Thu, Nov 6, 2008 at 12:00:02 PM
Killing error while saving file to central
Mon, Aug 18, 2008 at 1:58:13 PM
REVIT 2015 "Can't create this type of element in this view in the current mode"
Mon, Apr 20, 2015 at 9:34:06 AM
changing one element type to another type
Thu, Feb 5, 2009 at 2:11:33 PM
Keeping an Element Keynote from changing?
Mon, Apr 15, 2013 at 12:14:43 PM
Page generation time: 1.8693
