Forums >> Revit Building >> Technical Support >> New family tamplate
Thu, Nov 10, 2011 at 3:17:27 AM | New family tamplate
nirim
5 Stars: 12 Votes
Here is a problem, when load family from metric library all very well and all the family there but when I go to new family command I can’t find any family template. Probably I didn’t define the path for them properly. Can someone advise me on that?
Regards
nirim
p.s. i have revit ARC 2011
Thu, Nov 10, 2011 at 7:09:07 AM | New family tamplate
Paths are set under the Revit R pulldown - options.
Mon, Nov 14, 2011 at 4:41:16 AM | New family tamplate
nirim
5 Stars: 12 Votes
Hi there WWHub
Thanks for the comment.
The thing is that in my program data\ Autodesk\ RAC2011\ UK I have the family’s’ library files and not the families’ templates to use when creating  new family. And nor are in the UKTempl. I set the file location to be:
Default template file = C:\ProgramData\Autodesk\RAC 2011\UKTempl\DefaultGBRENU.rte
Default path for user files = C:\ProgramData\Autodesk\RAC 2011\UKTempl
And Default path for family template file = C:\ProgramData\Autodesk\RAC 2011\UK
And still can’t find them.
nirim
Mon, Nov 14, 2011 at 7:55:13 AM | New family tamplate
Do a search on your system for *.rte files.  Then set you path accordingly.
Templet
Sat, Oct 27, 2012 at 6:52:33 PM
Create a family that includes another family
Tue, Oct 11, 2022 at 12:32:18 PM
Can you use an IFC file in a family. or use one like a family?
Tue, Aug 7, 2012 at 4:27:00 PM
14
Detail Family Line weight sub-catoagories gone when family put into project
Tue, Aug 30, 2016 at 6:52:17 AM
11
"Can't Regenerate Family ____. Edit Family to modify it." Error message
Wed, Aug 26, 2020 at 11:19:36 AM
Page generation time: 1.4168
