Forums >> Revit Building >> Technical Support >> Slabs
Tue, Nov 8, 2011 at 4:57:07 PM | Slabs
luisrpv
Hello Revit Gurus,
I have two slabs. A structural slab and an architectural slopped topping slab. I need to model the void space between them so I can get quantities for what will end up being a "foam" filling.
Any Suggestions? i tried copying the slopped topping slab, moved it to the bottom face and tried to cut the excess with a generic void but the quantities did not change.
Thanks
Wed, Nov 9, 2011 at 9:56:00 AM | Slabs
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Add the foam to your topping slab bottom.
Floor slabs showing dashed instead of Solid
Wed, Jun 5, 2013 at 5:53:00 PM
12
Walls cutting slabs
Fri, Jan 23, 2009 at 1:57:20 PM
highrise towers slabs-walls joining
Tue, Jun 1, 2004 at 6:18:09 PM
new slabs, existing slabs, and the nature of constraint(s)
Wed, Dec 11, 2013 at 12:21:24 PM
Sloped slabs and spot elevations
Thu, Mar 6, 2008 at 1:18:13 PM
Page generation time: 0.1569
