12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> Sheet question
6 Posts No Rating |
I am trying to setup print sheets for my revit model.
For all elevations and plans, if I need 1/16" scale on 11x8.5 sheet, 1/8" on 11x17, and 1/4" on even larger paper.
In that case, do I really need to create each views with 3 diffrent scales so I can insert each of them into different sheet?
Thank you so much.
Yes, if you need to print them at the same time, then you will need three seperate views. Read about dependent dependent views in your HELP.
6 Posts No Rating |
oh.....that's too bad...
look like dependent view doesn't work for different scale situation...
So you usually have this kind of situation in project browser?
-Floor Plan
Level 1-1/16" 8.5x11
Level 1-1/8" 11x17
Level 1-1/4" 22x34
Level 2-1/16" 8.5x11
Level 2-1/8" 11x17
Level 2-1/4" 22x34
-Elevation
East-1/16" 8.5x11
East-1/8" 11x17
East-1/4" 22x34
West-1/16" 8.5x11
West-1/8" 11x17
West-1/4" 22x34
North-1/16" 8.5x11
North-1/8" 11x17
North-1/4" 22x34
South-1/16" 8.5x11
South-1/8" 11x17
South-1/4" 22x34
VERY LONG Project Brower!!!
Edited on: Wed, Nov 9, 2011 at 7:32:25 PM
Look through your help file for browser organization. You can easily sort your project browser to make it easier to navigate.
Adding parameters to Sheet List question |
Wed, Apr 25, 2012 at 12:09:19 PM
Sheet Index question |
Fri, Mar 22, 2013 at 11:30:35 AM
sheet index.. |
Tue, Jun 17, 2014 at 9:10:40 AM
Print to PDF |
Fri, Jan 23, 2015 at 6:47:45 AM
Links to each sheet in sheet index |
Sun, Aug 21, 2016 at 11:06:31 AM
