Forums >> Revit Building >> Technical Support >> Please Help-Revit 2011-Creating a single sloped roof
Tue, Nov 8, 2011 at 11:31:01 AM | Please Help-Revit 2011-Creating a single sloped roof
hcjames570
I am attempting to model an irregular shaped roof. The shape is irregular in plan and sloping in one direction only. I have attempted using the roof command and adjusting sub elements as well as modelling the roof as an in place mass and translating it as a roof.
the roof slopes from the front to the back at a constant angle. Can someone suggest the best method for modelling the shape? It would be most appreciated as i am running on empty.
Tue, Nov 8, 2011 at 1:34:20 PM | Please Help-Revit 2011-Creating a single sloped roof
rastamanCP
rastamanCP Avatar
4 Stars: 4 Votes
Try this;
Model use the roof by footprint tool.
In plan, draw the outline of your roof footprint by using the select tool and pick all of your exterior walls (see image 0)
Before finishing the sketch, select each boundary line and uncheck "Defines Slope", EXCEPT for the for the line from which you wish to be the high point of your roof slope (see image 1).
Select the line which you have given a slope, and in it's properties change the slope to a negative value (i.e. -1"/12")
Finish your sketch. The roof should look like image 2.
Tue, Nov 8, 2011 at 1:47:00 PM | Please Help-Revit 2011-Creating a single sloped roof
hcjames570
YES. thank you, it works...very easy..i should have known.
thank you again
Tue, Nov 8, 2011 at 2:50:01 PM | Please Help-Revit 2011-Creating a single sloped roof
rastamanCP
rastamanCP Avatar
4 Stars: 4 Votes
no problem Smile
Edited on: Tue, Nov 8, 2011 at 2:54:49 PM
Sloped Roof
Mon, Nov 10, 2008 at 12:40:48 PM
SLOPED FLAT ROOF
Sat, May 9, 2009 at 9:09:38 AM
creating subtle slopes for a flat roof in Revot 2011
Tue, Mar 8, 2011 at 8:26:33 AM
How to miter a fascia on a sloped roof?
Fri, Aug 24, 2012 at 7:48:23 AM
single roof plane of multiple slopes
Mon, Jul 11, 2005 at 8:09:38 PM
Page generation time: 1.5592
