25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> rail 1 and baluster heigth
10 Posts No Rating |
hello there!
I am having some stupid problem but I can't understand how to fix it:
I designed a baluster -from the baluster template in revit-
I uploaded into my project
I set all the rails perfectly, but the rail1 is always outside the baluster profile, there is no parameter, but it looks like that the baluster height is linked with that rail.
any suggestion?
thanks.
Maybe this can help you, you need to understand how it works: http://docs.autodesk.com/REVIT/2011/ENU/filesUsersGuide/WS1a9193826455f5ffa23ce210c8754311513e9.htm
http://docs.autodesk.com/REVIT/2011/ENU/filesUsersGuide/WS46b90c3cb2c58caddf503fc9951c5a8-7f15.htm
http://docs.autodesk.com/REVIT/2011/ENU/filesUsersGuide/WS46b90c3cb2c58caddf503fc9951c5a8-7f13.htm
no way!
i understand the problem, but I cannot find it, I almost did it, but I think I ma missing something important.
when I try to add the last rail with the same process i destroy everything, but I can't understand who is related with who!
what do you think?
test rail
Set baluster on Bottom Rail |
Thu, Mar 29, 2012 at 8:59:47 AM
2015 use baluster per tread on stair (with no top rail?) |
Thu, Sep 3, 2015 at 4:50:57 PM
Rail not Attaching to Baluster |
Sat, Oct 10, 2009 at 8:14:19 AM
Top rail offset |
Wed, Jun 21, 2017 at 11:14:51 AM
Baluster Top Offset Issue |
Tue, Jan 12, 2016 at 8:43:40 AM
