Forums >> General Discussion >> Revit Project Management >> Furniture as detail components
Mon, Nov 7, 2011 at 7:37:42 PM | Furniture as detail components
nematsvehclav
5 Stars: 2 Votes
I am looking for a library of families of furniture elements, preferably, which is only detail components. I really don't need 3D families for my furniture - simple 2D detail components for each plan I got would do just fine and would also not overload the whole model and file because the workflow I want to implement is that I only load those 2D detail components into each plan view I got and that's all instead of having them in the model all around in general, which would display them in all 3D view etc and would, as I said, make things harder to work with. Any suggestions?
Wed, Nov 9, 2011 at 3:44:07 PM | Furniture as detail components
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
you can load them in as 3D elements, then turn them off in other views, or make a duplicate view with detailing if you only want to see the furniture in that view, I think it will work like that.
Wed, Nov 9, 2011 at 3:47:41 PM | Furniture as detail components
nematsvehclav
5 Stars: 2 Votes
It sure will, but it is not what I am aiming for, as I said, I'm trying to keep a relatively small file size, not overloading it by loading in too many 3d objects such as furniture families and so on.
Thanks anyway!
Wed, Nov 9, 2011 at 5:30:43 PM | Furniture as detail components
If you can only find 3D furniture then use them.  You don't say how big your project is but I doubt they will not overload your project.
We often use a combination of 3D, 2D or 2 1/2D items.  If we need the items to show in plan and elevation views, then we want 3D or 2 1/2D families.
Furniture Tags & Sketchup Furniture Components
Fri, Dec 4, 2015 at 9:35:33 PM
Furniture, Doors, Casework, In Place Components have x-ray, see through properti
Wed, Jan 25, 2012 at 4:07:10 PM
Detail components in multiple views.
Tue, Aug 18, 2009 at 2:46:35 PM
Visibility/Graphics and Detail Components
Wed, Feb 23, 2011 at 2:53:36 PM
Detail Components or Symbolic Lines?
Tue, Apr 14, 2015 at 7:11:14 AM
Page generation time: 2.9383
