Forums >> Revit Building >> Technical Support >> Point Clouds Origin to Origin
Mon, Nov 7, 2011 at 6:20:06 PM | Point Clouds Origin to Origin
peter00
I was previously under the impression that importing a point cloud with origin to origin meant that the origin (0, 0, 0) in the point cloud would be placed at (0, 0, 0) in Revit.
However in my testing it looks like that is not the case. Am I simply doing something wrong or is there a way to do what I need? Thanks!
Mon, Nov 7, 2011 at 6:36:56 PM | Point Clouds Origin to Origin
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
It would be the basepoint of the actual survey. Revit does not have 0,0,0. What type of scanner are you using?
Tue, Nov 8, 2011 at 11:23:30 AM | Point Clouds Origin to Origin
peter00
I installed the 2 updates to Revit Architecture, and now the origin matches up correctly...thanks though!
Origin to Origin
Tue, Jul 5, 2011 at 8:18:16 AM
Acad Import - Origin to Origin
Wed, Aug 1, 2007 at 5:57:25 PM
linking models via origin to origin problem
Wed, Sep 30, 2015 at 10:20:09 AM
Relocate project origin?
Tue, Dec 21, 2010 at 11:40:27 AM
Internal Origin NOT At 0,0,0 ?
Tue, Sep 1, 2020 at 7:25:21 AM
Page generation time: 0.1226
