Forums >> Revit Building >> Technical Support >> Unrecoverable Error - Decal
Tue, Dec 6, 2005 at 10:50:43 AM | Unrecoverable Error - Decal
cirostratus
I am trying to place a decal and everytime I hit the decal button I get an unrecoverable error message and have to restart revit. Anyone else having this problem or have any idea if there is a way to keep this from happening? Thanks for your help..... PS.. This happens on multiple computers.....Just hitting the decal button triggers the error.....
Tue, Dec 6, 2005 at 3:59:29 PM | RE: Unrecoverable Error - Decal
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Hmm, i do remember having a similar problem back in V6 or something. Have you tried redirecting the image location that its looking for... Try not to use a UNC address, for instance \serverimage.jpg instead use a mapped drive if you're not already... i:image.jpg Would need more information to comment further; What kind've surface are you trying to place the decal on or does it do this on all surfaces? Do you have the latest build installed? If not try the latest build first. Have you done an audit on the file? If you've exhausted all possible options send to support.
Revit 2008 - Unrecoverable Error when Opening Program
Mon, Mar 24, 2008 at 11:14:57 PM
IFC Export - Unrecoverable Error - Aborted
Wed, Feb 26, 2014 at 8:15:09 AM
uNRECOVERABLE ERROR WHILE PUBLISHING .DWF SET
Tue, Feb 13, 2007 at 1:53:26 PM
Decal rendering
Sun, Nov 9, 2008 at 4:02:33 AM
Opening 2008 file in 2009 causes "Unrecoverable error" crash
Tue, Jul 28, 2009 at 1:36:33 AM
Page generation time: 0.1089
