Forums >> Revit Building >> Technical Support >> Course Detail Level Exposes Wall Ends
Fri, Nov 4, 2011 at 12:49:30 PM | Course Detail Level Exposes Wall Ends
rastamanCP
rastamanCP Avatar
4 Stars: 4 Votes
Hi All,
For our CD Architectural Plans we would like walls to show at the "Course" detail level, i.e., without various layers of material. However, when we adjust our view template to have wall detail level shown at course, the ends of all our walls suddenly appear, which we don't want either (see screen shots). I've checked several times and all walls are in fact joined. Any thoughts as to what might be the issue here?
Fri, Nov 4, 2011 at 1:16:57 PM | Course Detail Level Exposes Wall Ends
Those lines exist because you are using different walls or you have join wall turned off on the stub wall shown.
Also - read this in your HELP: Applying a Function to a Layer of a Compound Structure
That explains how layer number can affect joins.
Wall Detail Level
Mon, Oct 27, 2008 at 2:25:34 PM
non orthogonal wall ends
Wed, Jul 18, 2007 at 12:51:57 PM
Wall Ends No going to Gridlines
Fri, Apr 9, 2010 at 2:04:02 PM
Detail level - arch vs structure
Tue, Jan 20, 2009 at 9:05:50 AM
fine detail missing on duplicated wall, plan view??
Mon, May 1, 2006 at 8:31:20 PM
Page generation time: 1.3270
