Forums >> Revit Building >> Technical Support >> Graphic problems with hatches and lines
Fri, Nov 4, 2011 at 8:29:30 AM | Graphic problems with hatches and lines
Laura83
Hi
I'm on the verge of insanity because I can't seem to find out why lines disappear on elevations, sections ect. It's mostly hatches that become irreconcilable but also sometimes a simple outline of a roof, wall ect. I'm using RevitArcchitecture2011. It isn’t on the screen and it doesn’t show on prints - but the hatch is still there - just not visible (see attachment)… I really hope someone can help me with this.
Laura
Fri, Nov 4, 2011 at 8:38:03 AM | Graphic problems with hatches and lines
This is probably a graphics card issue.  I have never seen this as a Revit issue.  Tell us a little more about your system and if you have hardware acceleration on.  If you have that on, you might try turning it off.  Under the Revit R pulldown / options / graphics tab.
Fri, Nov 4, 2011 at 9:16:27 AM | Graphic problems with hatches and lines
Laura83
I checked and don't have the acceleration on. I'm not quite sure what information that'll be useful for you but can tell you that I run windows 7 professional, with processor: Intel® Xeon® CPU W3520 @ 2.67GHz and my graphic card is a NVIDIA Quadro FX 1800… Tell me if it wasn’t these informations you were looking for?
Fri, Nov 4, 2011 at 9:34:53 AM | Graphic problems with hatches and lines
Typhoon asks if you have installed the WEBs update for 2011 and if you installed the latest drivers for that GR. Card
Problems with Scaling Hatches
Tue, Mar 25, 2014 at 4:15:30 PM
Export to DWG: distinguish Wall hatches from the inner and outher wall lines
Wed, Mar 1, 2006 at 8:34:41 AM
Arc Lines display as straight lines
Sun, Jun 12, 2011 at 10:07:46 AM
How To Turn Off Hatches
Mon, Feb 11, 2008 at 3:27:14 PM
Graphic problems while in 3D Realistic view in 2013
Tue, Sep 25, 2012 at 4:10:41 PM
Page generation time: 3.8060
