Forums >> Revit Building >> Technical Support >> toposurface
Tue, Dec 6, 2005 at 5:18:18 AM | toposurface
mwarch
I am having trouple with creating subregions on a toposurface. I created the toposurface from an imported cad format. On a certain section of the surface it does finish the subregions but on the other side it says " The Site Surface failed to triangulate." Please help if possible. Urgent. Thanks
Tue, Dec 6, 2005 at 5:58:48 AM | RE: toposurface
eldados
eldados Avatar
4.5 Stars: 8 Votes
make sure that all your lines have a correct Z value and not all over the place, also, make sure they are closed... sometime when data is missing it fails...
Integrator
KarelCAD
Tue, Dec 6, 2005 at 7:02:45 AM | RE: toposurface
mwarch
double checked all and thy still dont work. Can,t even coppy existing subregions to this negative area. Gives the same error report. Any other solutions? Thanks
Tue, Dec 6, 2005 at 1:27:02 PM | RE: toposurface
arccodex1
3 Stars: 1 Votes
I've found that Revit is very good at generating topography from AutoCAD files, but very poor when you want to edit the surface in any way (especially for large sites). I got the same error frequently ( The Site Surface failed to triangulate.) If you have to show roads and pathways (subregions) in any 3D view I can't give you much help, sorry. But if all you want to do is show the roads and pathways in plan view on a large site model, I've resorted to importing DWGs and overlaying the information. Hope that helps.
Tue, Dec 6, 2005 at 3:49:57 PM | RE: toposurface
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Use the simplify surface tool before applying the subregions. This will remove excessive points and hopefully fix this problem. The resulting simplified surface is nearly exactly the same as the original in most cases just simpler...
Flat Toposurface
Thu, Aug 3, 2017 at 8:58:49 AM
Toposurface&subregion problems
Thu, Apr 16, 2009 at 1:47:06 AM
Toposurface in Elevations
Thu, Aug 27, 2009 at 1:51:06 AM
what is the easy to do toposurface
Mon, Feb 27, 2006 at 8:44:07 AM
14
Toposurface
Tue, May 11, 2010 at 9:04:45 AM
Page generation time: 0.1509
