Forums >> Revit Building >> Technical Support >> linked dwg's
Thu, Nov 3, 2011 at 3:36:44 PM | linked dwg's
Ptrdckrsn
Ptrdckrsn Avatar
1 Stars: 1 Votes
is there any type of notification i can recieve when the file is updated, or do i have to reload manually on mty own.
Thu, Nov 3, 2011 at 10:02:26 PM | linked dwg's
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
DWG's are typically reloaded (if they can be found), each time you open the file.  If you are already in session, then there is no notifications, you would have to manually reload.
Regards,
Chris.
Rotate linked DWG for elevation drawing
Thu, Aug 17, 2006 at 9:59:28 AM
Retain visibility if the linked dwg's are updated outside REVIT
Fri, Nov 9, 2007 at 10:14:52 AM
Linked DWG's & Model Display
Wed, Aug 10, 2016 at 6:09:33 PM
Reloading Linked DWG's
Sat, Jan 28, 2006 at 5:51:05 PM
Annotations accidentally snapped into linked dwg (Imported categories)
Tue, Jul 9, 2013 at 5:53:11 AM
Page generation time: 1.0241
