16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> creating a solid mass geaometry
1 Posts No Rating |
how do i create a mass geometry as solid.i tried tried using void extrusion on a massing i have alreading created , but it seems i can't make void extrusion on the mass because its doesn't exist as solid geometry.
I hate the term mass if your not in conceptual massing. If your in a project and you are doing an in-place component, then put it in the right category instead of mass.
All solid (Revit) elements can be cut by voids, you just have to follow the correct process. If you are creating an in-place family with a solid and void, make sure your void is set to cut the solid before you finish the family. If you are using an in-place void to cut a placed family, you must select the object to be cut before you finish the void family.
Autocad 2011 Solid To Revit 2011 Mass floor error |
Mon, Feb 28, 2011 at 7:20:10 AM
Creating a solid mass from a toposurface |
Wed, Mar 21, 2012 at 3:37:32 PM
Sphere Mass - Changing the mass into a roof |
Tue, Apr 16, 2013 at 8:25:38 AM
creating mass through solid sweep |
Sun, May 13, 2007 at 5:30:43 AM
Sweeping Solid In-Place Mass |
Tue, Apr 27, 2010 at 3:30:38 AM
