18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Make Walls Grey and Transparent in Plan view 'Fine Detail'
3 Posts No Rating |
Is there a way to make my walls in plan view appear as such (see attachment) in "fine detail view (as opposed to Coarse detail view)"!? I changed the coarse fill Pattern to Solid and coarse scale fill color to Grey in the Graphics box, but when I switch to Fine view, it reverts back to white!? I hope this is making sense!? Thank you so much in advance! You revit experts are the best!!!!
2 Posts No Rating |
Do you mean that it is changing from Gray, when 'coarse', to White when 'fine'? If so, I believe that it should stay the same unless your details are set to hidden line or wireframe.
In fine / medium mode, cut patterns are assigned by material - not by wall definition.
How did you create that image? You say it is a coarse view that you changed your fill? I doubt that. Coarse views will not show layers and in addition to that, you can't create a fill that has both a solid fill and a pattern.
Are you teasing us with something we are not aware of? - Fess up.
Problem with 'Coarse' & 'Fine' view options |
Thu, May 16, 2013 at 2:07:40 AM
fine detail missing on duplicated wall, plan view?? |
Mon, May 1, 2006 at 8:31:20 PM
When I make an ''Area plan'' not all the original elements show up. |
Thu, Aug 15, 2019 at 8:17:46 AM
Wall in Plan View: Details |
Tue, Mar 12, 2013 at 11:22:59 AM
Grey out Truss |
Thu, Jan 5, 2006 at 10:04:52 PM
