19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Cannot tag a door that has been modeled in place.
10 Posts No Rating |
I created a door by modeling it in place. When I started the model-in-place command I set the Family Category to Doors. I then modeled it as an extrusion. After I finished modeling I tried to tag the door and nothing happened. Also when I select the component and go to Type Properties, the Family and Type are blank and it won't let me choose anything in the drop down menu. Please help.
If you established the category when you created your door, the standard door parameters will be there. There is no family and type for in-place families so if you need that in your tag, you are in trouble. Remake your family in the family editor.
Thank you.
TAG A COLUMN THAT HAS BEEN MODELED IN PLACE |
Tue, Oct 26, 2010 at 10:48:01 AM
Door tag placement?? |
Thu, Jun 8, 2006 at 11:44:11 PM
Door Tag Locations. |
Wed, Aug 24, 2011 at 12:48:11 PM
Residential Door Tag |
Fri, Jul 7, 2006 at 8:18:54 PM
door tag exposing the door-width |
Wed, Sep 16, 2009 at 4:52:04 PM
